Section view of 3D sketch geometry (Survey)
pmaxwellNKJEX
pmaxwellNKJEX
I have a new challenge.
We are designing brackets to hold cables in a vertical line down a 250m deep shaft.
The shaft is not perfect and drifts up to 700mm from vertical.
We have been given a survey of the shaft at 1m intervals.
I have imported the survey lines to inventor, and I've got the lines to show up in the idw, but...
When I take a section view with a section depth of 1m, it still shows the complete survey from top to bottom of shaft.
Paul.
johnsonshiue
Hi! I could be wrong but I don't think Inventor was designed to create section view of this kind of part. First, the geometry already exceeds the valid model range (+-100m in X, Y, and Z directions). In a section view Inventor only cuts surface bodies, solid bodies, and mesh bodies, not wire bodies.
Many thanks!
Software Test Engineer
pmaxwellNKJEX
Thanks for your reply, even though It's not the resolution I hoped for.
Can you suggest how I might be able to achieve what I want to achieve?
johnsonshiue
Hi! I am not sure if AutoCAD or Revit can do this. But I am sure Inventor cannot do it.
Many thanks!
