Created Simplified Part from Assembly But it is Not Visible
Hi all,
I'm still trying to create a simplified part from an assembly in order to have the part 3D printed. After correcting a constraint error on my assembly, I thought that my assembly was complete and ready to go. I opened the assembly file, clicked on the SIMPLIFY button, and waited for Inventor to make the new part file. Inventor did create a new (simplified) part file but there is no visible part in the field of view.
There were no error messages during the SIMPLIFY conversion. However, there is a lightning bolt next to the original assembly file at the bottom of the model tree (See attached screenshot of the Simplified Part Model Tree). When I hover the mouse over the lightning bolt, a pop-up says, "Needs Update." NOTE: I have tried the SIMPLIFY process several times. I even obtain a simplified part with NO lightning bold at the bottom of the model tree, but none of the simplified parts are viewable.
I have also attached a screenshot of the original assembly file, including the expanded model tree. (If it helps)
I went back to the folder containing every part, including every revision of every part associated with this assembly, and opened them up in Inventor, one by one, to make sure that the path for the reference (children?) files could be found and were up-to-date within Inventor.
I'm out of ideas and exhausted. I greatly appreciate any help.
David
