Scaling sheet metal parts with rips/holes (to produce flat pattern)
Message 1 of 9
Hello forum,
I have been using Inventor to create 3D models of sheet metal animals that we weld to make yard art.  I have an animal that I want to scale down from the original to make a "baby" animal. My 3D model contains 40+ solids with an assortment of holes and rips that enable me to flatten the flanges so they can be cut. All this is fine and I love using Inventor for this purpose.
The problem that I am now having is that I want to scale my part that contains the solids with rips/holes.  I have tried scaling the original in three ways:
1. Using Direct Edit to scale everything
2. Scaling when I create the sheet metal component for the assembly
3. Deriving the part with a scale factor
In doing each of these, I have the problem that the scaled part cannot be flattened. In scenario 1, I see that the rip and hole in the assembly have not been scaled.
Is there a way to do this? I would hate to have to redo all rips/holes after scaling as there are MANY of them.
I am including a zip file containing a simple example with a lofted flange with a rip that I cannot scale successfully to create the flat patterns.
Thanks for your time.
Elaine
Accepted solutions (3)
Replies (8)
Message 2 of 9
johnsonshiue
Hi Elaine,
Direct Edit specifically ignore holes to avoid manufacturing error. What you could do is to derive the part or body as a separate part. Then change scale factory in Derive dialog.
Many thanks!
Software Test Engineer
Message 3 of 9
Hello Johnson,
I did try deriving one part only with a scale factor and it didn't seem to work for me.
Are there specific settings/options I must use for the derivation to work so that the holes/rips are included to scale?
Elaine
Message 4 of 9
JDMather
You must also consider the sheet metal Thickness.
When you scale the part are you also scaling the Thickness?
Message 5 of 9
JDMather
Message 6 of 9
That did the trick!  I was not scaling the thickness. I can now flatten it.
Thank you both for your help.
Elaine
Message 7 of 9
JDMather
Ah, but are you going to make the babies out of thinner material or out of the same thickness material?
Message 8 of 9
Well actually, it will be cut from the same thickness material.  I tried deriving with a thinner thickness in my real model and I still could not get it to unfold. Argh!
I think what I will end up doing is scaling the larger already flattened sheet metal pieces (.dxf).  I would have liked to have done it all in Inventor, but it doesn't seem possible.
I definitely do not want to have to re-rip and re-hole my "mini" model.
Elaine
Message 9 of 9
johnsonshiue
Hi! You don't need to remodel the whole thing. In the scaled model, you can simply use the following workflow to get the correct thickness.
Options A:
1) In the source sheet metal part, double-click on a face in one side so all faces are selected, including the tangentially connected ones.
2) Thicken/Offset -> output = surface -> distance = 0.
3) In the derive part, edit Derive feature -> exclude the solid but include the surface.
4) Thicken the scaled surface to desirable thickness.
Option B:
1) Open the derive part.
2) Double-click on a face in one side so all faces are selected.
3) Thicken/Offset -> output = surface -> distance = 0.
4) 3D Model -> Edit -> Delete Face -> Lump selection -> select the solid body.
5) Thicken -> Quilt -> pick the offset surface -> distance = Thickness.
Many thanks!
