Scaling sheet metal parts with rips/holes (to produce flat pattern)
Hello forum,
I have been using Inventor to create 3D models of sheet metal animals that we weld to make yard art.  I have an animal that I want to scale down from the original to make a "baby" animal. My 3D model contains 40+ solids with an assortment of holes and rips that enable me to flatten the flanges so they can be cut. All this is fine and I love using Inventor for this purpose.
The problem that I am now having is that I want to scale my part that contains the solids with rips/holes.  I have tried scaling the original in three ways:
1. Using Direct Edit to scale everything
2. Scaling when I create the sheet metal component for the assembly
3. Deriving the part with a scale factor
In doing each of these, I have the problem that the scaled part cannot be flattened. In scenario 1, I see that the rip and hole in the assembly have not been scaled.
Is there a way to do this? I would hate to have to redo all rips/holes after scaling as there are MANY of them.
I am including a zip file containing a simple example with a lofted flange with a rip that I cannot scale successfully to create the flat patterns.
Thanks for your time.
Elaine
Accepted solutions (3)
Replies (8)
johnsonshiue
Hi Elaine,
Direct Edit specifically ignore holes to avoid manufacturing error. What you could do is to derive the part or body as a separate part. Then change scale factory in Derive dialog.
Many thanks!
Software Test Engineer
Hello Johnson,
I did try deriving one part only with a scale factor and it didn't seem to work for me.
Are there specific settings/options I must use for the derivation to work so that the holes/rips are included to scale?
Elaine
JDMather
You must also consider the sheet metal Thickness.
When you scale the part are you also scaling the Thickness?
JDMather
That did the trick!  I was not scaling the thickness. I can now flatten it.
Thank you both for your help.
Elaine
JDMather
Ah, but are you going to make the babies out of thinner material or out of the same thickness material?
Well actually, it will be cut from the same thickness material.  I tried deriving with a thinner thickness in my real model and I still could not get it to unfold. Argh!
I think what I will end up doing is scaling the larger already flattened sheet metal pieces (.dxf).  I would have liked to have done it all in Inventor, but it doesn't seem possible.
I definitely do not want to have to re-rip and re-hole my "mini" model.
Elaine
johnsonshiue
Hi! You don't need to remodel the whole thing. In the scaled model, you can simply use the following workflow to get the correct thickness.
Options A:
1) In the source sheet metal part, double-click on a face in one side so all faces are selected, including the tangentially connected ones.
2) Thicken/Offset -> output = surface -> distance = 0.
3) In the derive part, edit Derive feature -> exclude the solid but include the surface.
4) Thicken the scaled surface to desirable thickness.
Option B:
1) Open the derive part.
2) Double-click on a face in one side so all faces are selected.
3) Thicken/Offset -> output = surface -> distance = 0.
4) 3D Model -> Edit -> Delete Face -> Lump selection -> select the solid body.
5) Thicken -> Quilt -> pick the offset surface -> distance = Thickness.
Many thanks!
