Inventor Forum
Missing content files
4 REPLIES 4
661 Views, 4 Replies
I have some Inventor drawings that were created on a computer that I do not have access to its content center files any more.
I have tried every possible way to regenerate those parts by trying to find them manually in the Inventor library but i had no luck.
if anyone could share with me those drawings that would be great.
ANSI B18.6.4 - 1_4-20 UNC - 1(3) C I
ANSI B18.3 - 10-24 UNC - 0.625(18)
FHS-440-10
IFI 100_107 - 1_4 - 20 Top Insert Type.ipt
IFI 111 - 1_2-13 UNC x 1.25.ipt
ANSI B18.6.3 - 8-36 UNF - 1.5(11).ipt
IFI 100_107 - No. 8 - 36 Metal Type.ipt
Unbrako - 1_2 x 7_8 - 13(10).ipt
ANSI B18.3 - 1_4-20 UNC - UNC - 0.5(1).ipt
ANSI B18.6.3 - 8-32 UNC - 0.5(15_).ipt
ANSI B18.6.3 - 6-32 UNC - 0.3125(5).ipt
IFI 111 - 1_2-13 UNC x 1.ipt
ANSI B18.6.3 - 8-36 UNF - 2(11).ipt
ANSI B18.3 - 10-24 UNC - 0.625(18).ipt
Unbrako - 1_4 x 1_2 - 20(10).ipt
ANSI B18.6.4 - 1_4-20 UNC - 1.25(3) F IA.ipt
IFI 100_107 - No. 8 - 36 Top Insert Type.ipt
Unbrako - 1_2 x 1 - 13(10).ipt
ANSI B18.6.4 - 1_4-20 UNC - 1.25(3) F I.ipt
ANSI B18.3 - 5_16-18 UNC - 1.01(18).ipt
ANSI B18.6.3 - 6-32 UNC - 1.5(5).ipt
ANSI B18.6.3 - 6-32 UNC - 0.5(5).ipt
4 REPLIES 4
Marco.Takx
Hi @Anonymous,
you can also make a Assembly and place all the missing content center files and save the assembly
the files will be created.
Then you can Delete the Assembly but the content center files will be in your content center files folder.
The Assemblies with the missing files will now find the them.
If my post answers your question Please use  Mark Solutions!.Accept as Solution & Give Kudos!Kudos This helps everyone find answers more quickly!
Met vriendelijke groet | Kind regards | Mit freundlichem Gruß
Marco Takx
CAM Programmer & CAM Consultant
in reply to: Marco.Takx
i thought about doing that but the problem is i have no idea how to find most of those parts in the library using the part description!!
the file name doesn't tell you exactly what is that part.
kelly.young
@Anonymous I see that you are visiting as a new member to the Inventor Forum.
Welcome to the Autodesk Community!
If someone finds the files and posts them but the wrong version it will be useless, what version of Inventor are you using?
There has to be a bit more information than your list, for instance the Unbrako part has three different options, without knowing what kind it is somewhat difficult to amass the parts for you.
Can you attach your drawing that has the missing parts? Depending on how it's showing up in the browser, BOM, part list, etc the destination/description of the part might show which the location you want.
If you don't know what type of part you're looking for and just have those file names, it might be very difficult as I'm sure you've found.
Please select the Accept as Solution button if a post solves your issue or answers your question.
in reply to: kelly.young
thank you Kelly!
currently i have inventor 2018 but i believe those were designed using inventor 2015. sorry i cant share those drawings, those are company designs.
i dont have any paper work that shows the BOM.
thanks
