Saving File Windows Fills Entire Screen
EskimoBurns
Message 1 of 8
EskimoBurns
Hey,
Every time I save a file the 'save file' window fills the entire screen.
I can't resize or move the window around at all.
Has anyone else come into this?
I am using inventor 2021 and Win 10, 1909.
Thanks 🙂
Replies (7)
Message 2 of 8
mdavis22569
What happens if you pull the lower corner ... does it revert back to full screen each time you save?
Try the Inventor Reset Utility.
https://knowledge.autodesk.com/support/inventor/troubleshooting/caas/sfdcarticles/sfdcarticles/How-t...
Mike Davis
Message 3 of 8
EskimoBurns
Clicking and dragging from the corners/edges doesn't resize the window at all and every time I save a new file it fills the entire screen.
When I go to resize the my mouse does change into one of those double sided arrows.
I'll give that reset tool a try thanks.
Unfortunately no dice on the reset tool.
Message 4 of 8
mdavis22569
I'd try doing a clean uninstall / reinstall then
Shocked this isn't working
Mike Davis
Message 5 of 8
EskimoBurns
Yeah its very odd.
I'm reasonably confident I'm not making any mistakes with my ability to resize a window. I did it to firefox when I was writing this to check. ¯\_(ツ)_/¯
Thanks for your help!
Message 6 of 8
mdavis22569
Try Chrome .....
Mike Davis
Message 7 of 8
-niels-
Stupid suggestion, but what happens if you hold the "windows" key and press any of the direction arrows?
Niels van der Veer
Inventor professional user & 3DS Max enthusiast
Vault professional user/manager
The Netherlands
Message 8 of 8
EskimoBurns
Ayy that works a treat. Snapping it to the edge of the screen freed it from its frozen state and now it can be moved and resized.
Thanks a heap!
