Projecting a flat pattern onto a round object
Message 1 of 22
Hi, everyone
I have created this interesting pattern in work sheet that I will need to cut out into an object and then duplicate it in a circular pattern. However, after  projecting to 3D sketch, I can split only one out of many parts of the pattern and then I can't even project it again and do the rest of them.
This is how the pattern looks like:pattern projectionpattern projectionCan split only 2 curves at a timeCan split only 2 curves at a timecant split nor project the same pattern anymorecant split nor project the same pattern anymore
Accepted solutions (3)
Replies (21)
Message 2 of 22
admaiora
You can select only 1 profile at time.
Just make the sketch visible and repeat.
Admaiora
_____________________________________________________________________________
Facebook | Twitter | Youtube
Message 3 of 22
JDMather
Attach your *.ipt file here.
Message 4 of 22
Hi, thanks for the answer.
I tried to do that, however I couldn’t project the work sheet(which I made visible afterwards) on the the surface of the object anymore...
Message 5 of 22
mikejones
As JD already said, attach the part file for people to look at and help answer your question.
Mike
Autodesk Certified Professional
Message 6 of 22
Here it is
Message 7 of 22
mikejones
Ok so what exactly are you wanting to achieve with the split or the profile? Are you wanting to cut the shape out or simply split the face all around and if so what is the purpose of it?
What is the end result you're after is the main question here.
Mike
Message 8 of 22
I wanted to find a way How to make holes in the pattern form - so after splitting the projection, I would cut it out using extrude.
Message 9 of 22
Yeah and it would be all round
Message 10 of 22
mikejones
So like a plastic waste paper bin then.
Message 11 of 22
Yes exactly, I mean it's not gonna be that, but definitely gonna look like that.
Message 12 of 22
JDMather
Aren't Work Axis1&2 duplications of the Origin Y Axis?
Looking at your part in half-section view I suspect that you don't really intend this step in the geometry?
Message 13 of 22
Oops, no, that is a genuine mistake
Message 14 of 22
JDMather
I noticed several sketches that didn't appear to have any purpose?
See the Attached file - is this your true starting Design Intent?
In the Attached file - note the simplicity of Sketch1 and feature construction.
Oops, I had the angles wrong, but that is an easy fix.  Back in a minute...
Message 15 of 22
JDMather
No moving forward from here - I have genuine concerns that you have portrayed your true Design Intent.
Your sketch is not at an angle like the part face - is this your true Design Intent?
Wrap of sketch vs straight line projection returns different results, what is the true Design Intent?
Extrude-Cut vs Thicken Cut (or several other options) returns different results.  We will need to define your true Design Intent.
Message 16 of 22
1st - Yes
2nd - Straight line projection
3rd - Extrude cut
Look I'm a beginner and I'm doing this wrong I know... I just want it to look something like the plastic waste paper bin and figure out how to cut in the holes in some kind of a pattern... Thanks
Message 17 of 22
JDMather
See if you can reproduce the Attached file.
Ask questions if you run into trouble...
Or this...
I didn't take the time to get it exactly symmetrical, but I think you get the idea.
Message 18 of 22
mikejones
And another approach to the same end result. There are so many different ways to complete this, perhaps you should see how many you can find as it will help your understanding of the software and all of its features.
Mike
Message 19 of 22
You're truly amazing thank you sooo much.
I learned what I could with this program myself, but now I see your approach and steps... It's marvellous.
I actually have some questions - Was the second solid created automatically during the split between the parts with different angles? I see a sketch there, but I don't get how to follow on from there to make the solid.
Message 20 of 22
That's amazing!
Yeah, I have yet to understand a lot about this... This programme is just amazing! So many possible ways to achieve the desired outcome. I thought I would be stuck with this, thanks a lot!!!!!!
You don't find this quick and amzing support with many softwares.
