Save as IPT and STEP when saving in part window
matthew_mccartinLBLNC
I have an addon that makes it so when I hit save in a drawing it also saves it as a pdf in the same location. I would like something similar so when I am in an assembly/part and I hit save the part is saved as the .IPT or .IAM but in the same folder a STEP file is created along with it. Is this possible?
johnsonshiue
Hi Matthew,
You may want to take a look at the following discussion.
https://forums.autodesk.com/t5/inventor-forum/can-i-automate-exporting-a-stp-file-and-associated-dra...
Many thanks!
Software Test Engineer
