Announcements
Rotation
Rotation
This is a trial. I want to model a cylinder with 6 slightly twisted (5 degree) tooth. In the process I decided to make 3 similar sketches in 3 parallel planes with 5 degree turned and use loft command to make it.
But when I tried to rotate green colour sketch through 5 degree error message is coming. How to fix it?
undefined
Replies (7)
PaulMunford
Hi Fiatnm.
Try making the geometry into a sketch block first.
On a separate note, have you considered sweep with a twist?
Customer Adoption Specialist: Autodesk Informed Design
Help | Learn | Forum | Blog | Ideas | Sample content | Linkedin
mdavis22569
As @PaulMunford mentioned ... Sweep with a twist...
If this would work ..then give him the kudo's/solution ...
Mike Davis
Tooth are coming in a straight line, whether it is possible to make it come in a curved line like in this image.
undefined
mdavis22569
yes ..that's possible ...
but that's a different type of gear
you'll need to change the design you're using...
are you doing this tutorial?
https://www.youtube.com/watch?v=2erIPXUKdI8
Mike Davis
Not any tutorial, just curiosity.
mdavis22569
what version of inventor are you using again?
here you can see more of the twist at different angles....
of you gear you'll need the back side larger ...so  a loft would be best if that's the gear you want ...
The one you started and end with the same sketch, just rotated, so that's what Paul and I were showing you.
Mike Davis
Thanks.
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
