Inventor Forum
Rotation
7 REPLIES 7
Message 1 of 8
464 Views, 7 Replies
Rotation
This is a trial. I want to model a cylinder with 6 slightly twisted (5 degree) tooth. In the process I decided to make 3 similar sketches in 3 parallel planes with 5 degree turned and use loft command to make it.
But when I tried to rotate green colour sketch through 5 degree error message is coming. How to fix it?
7 REPLIES 7
Message 2 of 8
PaulMunford
Hi Fiatnm.
Try making the geometry into a sketch block first.
On a separate note, have you considered sweep with a twist?
Autodesk Marketing Manager D&M
Opinions are my own and may not reflect those of my company.
Linkedin Twitter Instagram Facebook Pinterest
Message 3 of 8
mdavis22569
As @PaulMunford mentioned ... Sweep with a twist...
If this would work ..then give him the kudo's/solution ...
Mike Davis
Message 4 of 8
in reply to: mdavis22569
Tooth are coming in a straight line, whether it is possible to make it come in a curved line like in this image.
Message 5 of 8
mdavis22569
yes ..that's possible ...
but that's a different type of gear
you'll need to change the design you're using...
are you doing this tutorial?
https://www.youtube.com/watch?v=2erIPXUKdI8
Mike Davis
Message 6 of 8
Not any tutorial, just curiosity.
Message 7 of 8
mdavis22569
what version of inventor are you using again?
here you can see more of the twist at different angles....
of you gear you'll need the back side larger ...so  a loft would be best if that's the gear you want ...
The one you started and end with the same sketch, just rotated, so that's what Paul and I were showing you.
Mike Davis
Message 8 of 8
Thanks.
