Rotating a part in a linear pattern
05oscide
05oscide
Hello!
Is it possible to rotate a part in a linear pattern? I am currently drawing a V6 from a tutorial in SolidWorks and making the camshaft and crankshaft. I noticed that in the video he was rotating the part around an axis in his linear pattern. Is there a similar action in Inventor or do I have to make an Assembly and rotate them manually?
This is the tutorial I was following. Camshaft is at 1h 48 min.
https://www.youtube.com/watch?v=Hna4V7-FJ08
CCarreiras
Hi!
What you see at minute 1h48m, is not a pattern, is a copy.
Later there's a pattern in part context.
You can do similar task in inventor.
CCarreiras
johnsonshiue
Hi! Another workflow to consider is Move Bodies (solids and surfaces are allowed).
Many thanks!
Software Test Engineer
05oscide
Thank you so much, this really helped me!
