Connect circular patterns of different sizes
po8527
po8527
I want to make a nozzle like the one observed in the file 6holes_0.4int_1.5ext_filled.ipt where the two outer faces have holes, but now I would like to have a different one where the holes in the bigger outer face are bigger than the holes of the smaller outer face. An initial idea of how this could look is in the file 6holes_0.4int_1.5ext_filledMod.ipt, where I have the two circular patterns in both faces with the desired dimensions, however I don't know how to connect the planes to make path that goes through the object and ending up having the nozzles with multiple holes. I know sweep can help me with this but I find it difficult to make the path for the sweep tool. Can you help me?
CCarreiras
Hi!
Would you place the parts here?
CCarreiras
