Inventor Forum
Rndering A stainless steel fastner?!
11 REPLIES 11
Message 1 of 12
1385 Views, 11 Replies
I keep messing with settings and i cant seem to get to what i like... anyone have recomendations on settings? Im new to this so all help is appreciated.
So far this is best i can do.
I want something more like
11 REPLIES 11
Message 2 of 12
Under the appearane tab, pick "Chrome - polished".  That should take care of it.
Message 3 of 12
mdavis22569
Check your materials.   You'll need to go to make it polished
also maybe change your rendering from 32 til satisfactory
this is one I'm working on currently:
Mike Davis
Message 4 of 12
-niels-
Welcome to the community!
You're not giving a lot of info on how you're trying to render or which version of Inventor, but maybe this screenshot can give you some ideas:
Niels van der Veer
Inventor professional user & 3DS Max enthusiast
Vault professional user/manager
The Netherlands
Message 5 of 12
in reply to: -niels-
Thanks all for the quick replies.
More info on what my setup is:
Appearence: Stainless Steel - Polished
Visual Style: Realistic
Shadows: Ambient
Lighting Style: Grey Room with exposure at 1.7
45 iterations
Image filtering: Gaussian Width: 3
From my understanding i thought ray tracing could not be used in conjuntion with the studio? I need to out put my image with no background hence why i havnt used the ray tracing...Screenshot (2).png
Message 6 of 12
mdavis22569
Are you changing the background to Presentation?
Mike Davis
Message 7 of 12
in reply to: mdavis22569
Yes i just turned background to presentation. I trying the ray tacing which look promising other than taking 10 years at the rate its going...
I still dont understand how to go from ray tracing to studio render, if its even possible
Message 8 of 12
-niels-
How "real" does your image need to be, because if that's important you might need to render in different software...
(example of 3DS Max, as i like that software)
You could change your background to "presentation" with a single (white) color as the background like Michael suggests...
Other than that it's mainly tweaking your lighting style and material.
Niels van der Veer
The Netherlands
Message 9 of 12
Its for a company website and ill end up doing a lot of them so id like to get a good set up to do them all.Screenshot (4).png
Finally i think we have a winner.
Thanks everyone. I Also might look into other software too. Right now ive got Keyshot trail but dont know how to use it!
Message 10 of 12
mdavis22569
My image was done in Studio ...
as was this one
Mike Davis
Message 11 of 12
Logan,
I think if you are going to do a lot of them then I would setup an assembly with all the lights and background walls that you need to make a good render.
Then just replace your subject in the assembly for all your different renders.
This way you only need to setup once and all your renders will come out the same.
Message 12 of 12
-niels-
If you need to do a lot of them and the setup you have now with the white background and ray-tracing is satisfactory, then i think that will be the quickest for you.
(As you can see in my 3DS Max render, that simple medium quality render already took over 8 minutes...)
So if you're happy with the result, i'd say stick with it!
Niels van der Veer
The Netherlands
