Inventor Forum
Reset Origin
5 REPLIES 5
vmontefusco
11108 Views, 5 Replies
Reset Origin
Greetings
Someone sent a assembly and its parts and the assembly origin is not correct. I'd like the top of the attach screen shot part to correspond the top of the origin cube.
Vince
5 REPLIES 5
johnsonshiue
in reply to: vmontefusco
Hi! Is the view orientation wrong or the parts are not in the X, Y, and Z you are expecting? If it is former, you can simply change ViewCube orientation. If it is latter, you need to use Direct Edit -> Body -> Rotate or Move Bodies command to transform the bodies.
Please feel free to attach the files here so forum experts can comment further.
Many thanks!
Software Test Engineer
SBix26
@vmontefusco You can either re-define the view cube as Johnson suggested, or un-ground and reconstrain the assembly.  The latter works well if the assembly has one grounded part and the rest constrained to it and each other; impossible if everything is simply grounded without constraints, as might happen with an imported assembly, or with a top-down modeling approach.
Sam B
Inventor Pro 2019.0.0 | Windows 7 SP1
LinkedIn
vmontefusco
in reply to: SBix26
Greetings and thank you for helping me!
"everything is simply grounded without constraints, as might happen with an imported assembly, or with a top-down modeling approach"
I brought the assembly in as an stp. It converted and I had a dozen or so parts for the assembly. The parts are NOT constrained, so I grounded all of the parts in the assembly in order to add my parts on top of this assembly. However, the assembly XYZ origin is not correct, especially when I bring in my parts to constrain to the assembly. I can live with this, but it would be nice if I could change the assembly to conform to the origin cube.
Thanks again
Vince
SBix26
If the imported assembly isn't too complex, I would typically re-constrain it.
Another possibility is to leave the imported assembly as is, then place it, properly constrained and grounded, into a new assembly and add your new components to that one.
Sam B
LinkedIn
vmontefusco
in reply to: SBix26
Greetings
It is too complex to constrain all of the parts, so I will simply live with what I have.
Thank you
Vince
