Replacing an old Title Block with a new Title Block in Inventor 2018
Message 1 of 15
I need to replace an old title block with a new title block in Inventor 2018.  How do I accomplish this?
Thanks in advance,
Travis
Replies (14)
Message 2 of 15
mcgyvr
Drawing resource transfer wizard..
https://knowledge.autodesk.com/support/inventor-products/learn-explore/caas/CloudHelp/cloudhelp/2016...
Message 3 of 15
Well, for whatever reason, the Wizard did not switch the title blocks with 100% accuracy, haphazardly scattering the text and symbols as pictured below.
Any ideas what might be the issue?
Message 4 of 15
mcgyvr
There "were" some reported issues not too long ago where the first titleblock would update properly but subsequent ones (done in the same batch) were not processed properly..
I thought those issues were addressed in an update not too long ago.. Not sure if thats whats happening to you though..
This could be a different issue..
@johnsonshiue... I will call Johnson to help here and he can take a look at your files and see whats going on and if there is a bug/issue he can get it recorded so it can be fixed..
Message 5 of 15
Thanks for your help, mcgyvr.  I appreciate it.
Message 6 of 15
kelly.young
Autodesk Support
Autodesk Support
Hello @Anonymous I see that you are visiting as a new member to the Inventor Forum.
Welcome to the Autodesk Community!
That definitely doesn't look right. Was the old template block information fully constrained or just laid down without constraints?
When you go into the new drawing block are the setup constraints broken?
It looks like some stayed put, was wondering if they had constraints and the other didn't. Might have to look at the files and how the wizard handled them.
Please select the Accept as Solution button if a post solves your issue or answers your question.
Message 7 of 15
Hello, @kelly.young.  Thanks for your help.
The old title block is partially constrained, but the new one is fully constrained.
I have attached the files.
Thanks again for your help,
Travis
Message 8 of 15
kelly.young
Autodesk Support
Autodesk Support
@Anonymous thank you for supplying the files to inspect. It appears that you are migrating from 2014 to 2018.
From what I have researched, with that large of a jump in releases you might see issues.
Ideally a jump of 1 release we will ensure proper migration, 2 releases should function as well, but any more you might see these types of issues.
If you have the ability to jump from 2014-2016-2018 this migration error might be eliminated. If you have been on a subscription basis you should be able to install 2016 and take care of this.
Not sure if that is the answer you are looking for but wanted to give you the information I found. If anyone has additional suggestions please let us know.
Message 9 of 15
MechMachineMan
@kelly.young I believe I had read somewhere from something posted by an Autodesk Employee that the suggestion for migration was now to migrate AS NEEDED.
If this is true, then any company who leaves a file for more than 2 years in between use will run into issues that they wouldn't have if they were told to migrate all files during every version change.
Seems a little misaligned currently.
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
Message 10 of 15
kelly.young
Autodesk Support
Autodesk Support
Thanks for the input @MechMachineMan I will continue to investigate this and might have to redact my statement if it is not correct but wanted to provide a workaround if possible.
Message 11 of 15
dan_inv09
I've had it be a text style issue.
The drawing you put the new title block into may be right justifying things that were set to be left justified when you created it or something. It helps to have specific text styles just for any special text, or really any text at all that goes in symbols or special borders as well. That should help when it goes into drawings that may have had styles that were different or that someone may have changed for whatever reason.
Although, while some of it may be line spacing, some of it appears to be more lines of text than "cells" for the text to go in and some of it appears to be doubled - and are those symbols even text? I've never seen the third angle projection thing in wingdings - so maybe there is something else entirely going on there.
Message 12 of 15
johnsonshiue
Hi Travis,
The behavior is wrong. The issue you report here seems to be a different one than what Brian was talking about. There was bug in recent Drawing Resource Transfer Wizard leading to working only for the first target drawing file. It has been fixed on 2017 and 2018 updates.
Could you tell me the exact process and the files you use to reproduce the behavior?
Many thanks!
Software Test Engineer
Message 13 of 15
You are welcome @kelly.young.  Again, thanks for your help.  I am going to consult our company's IT guy about migration next week when he returns from his vacation.  My tenure at this company has only been under Inventor 2018, so it seems reasonable to consult him about this issue.
Message 14 of 15
Hi @johnsonshiue,
Thanks for your help, sir.  Below is the process, step-by step, that I have went through:
Drawing Process Transfer Wizard 2018
> Click "Next"
> Select the Source Drawing ("CFS Standard 3_5) in C:\Users\Public\Documents\Autodesk\Inventor 2018\Templates
> Click "Next"
> Select "Old Title Block post Wizard.idw"
> Click "Next"
> Select "Yes" (or "No"- I have tried both)
            > Click "Next"
> Click "Start"
> Click "Exit"
Message 15 of 15
Hey @dan_inv09,
I'll look into the text discrepancy possibility.  Thank you.
