Inventor Forum
Search by Wire number in Browser
3 REPLIES 3
407 Views, 3 Replies
Hello there!
I have a file in which the wire harness of a bus has been imported from AutoCAD Electrical along with the wire numbers. When I click on a wire, it is highlighted in the window.
Now I want to be able to search a wire by its number, since there are too many wires to go through each time. This search is possible for the connectors that the wires are connected to, but not the wires. Is it possible to achieve this in another method? Does any property of the wire have to be changed while creating/importing the wiring harness?
Thank you,
Nina
Hello there!
Thank you,
Nina
Tags (2)
3 REPLIES 3
Yijiang.Cai
Yijiang.Cai
Hi Nina,
You are correct that it does not support to search the wire. But we could consider to use cable node in the location view to search the wires from Inventor browser. Please see the attached image.
River Cai
Inventor Quality Assurance Team
Autodesk, Inc.
Email: River-Yijiang.Cai@autodesk.com
Hi Nina,
River Cai
Autodesk, Inc.
in reply to: Yijiang.Cai
Dear Mr. Cai,
Thank you for the suggestion. The harness has been built using wires and not cables, and hence this option is not available.
Best Regards,
Nina
Dear Mr. Cai,
Best Regards,
Nina
kelly.young
kelly.young
Autodesk Support
Autodesk Support
@Anonymous has supplied a great idea suggestion, check it out and give it a vote!
IDEA: Search by wire number in Browser
Please select the Accept as Solution button if a post solves your issue or answers your question.
