Replace Model Reference (.iam with .ipt ?)
MikeKovacik4928
Advisor Advisor
MikeKovacik4928
Hi all
Having read a similar post
https://forums.autodesk.com/t5/inventor-forum/replace-model-reference-iam-with-ipt/m-p/3065154#M4055...
I see this is not a new issue at all.
I also have found a workaround.
I create a  new assembly with only the one part in it, that I want to replace.
I agree with the previous post that it would be useful to have that functionality in Inventor,
which apparently Solidworks does have.
See attached
Michael Kovacik
2d & 3d Autocad and Inventor designer/draughtsman
Draughting/Designing (Manufacturing) (31 yrs)
-Drawing Board (3 yrs)
--Cad (28 yrs)
---Cadkey (4 yrs)
---AutoCAD 2d & 3d (16 yrs)
---Inventor (4 yrs)
---Autocad and Inventor Simultaneously (4 years)
---(and recently Autocad/Inventor Customisation)
Autodesk Product Design Suite Ultimate 2018
Autocad 2018, Inventor Pro 2018
(personal licensed copy)
Johannesburg, South Africa
(Impossible only means you haven't
found the solution yet)
johnsonshiue
Hi! I have heard similar request before and it has been discussed internally. Unfortunately, there is no straight forward solution to do that technically. I recall there are similar ideas on Inventor Ideas forum. Please kudo the idea.
Many thanks!
Software Test Engineer
MikeKovacik4928
Thanks Johnson,
I will do that.
Mike
I have a drawing that has broken links - the links are broken because they used to point to an assembly (iam) they now point to a part (ipt).  I can't FIX it because it was broken in a way that is supposedly technically impossible.
I can't send anyone the file unless you want to sign a Draconian NDA (the process for which I can't even initiate), so trust me, version 29 works fine, version 30 has broken links pointing to the wrong type of file.  If it can be done by accident, it can be done on purpose.
SER4
I was able to use the Vault Copy Design and Replace the drawing's reference from the part with a reference to an assembly (after several Vault crashes and warnings).  HOWEVER, when I go to open up the drawing, all the drawing views are blank!
P.Eng. Mechanical Engineer
Dell Precision 5680 Laptop; Win11 Pro; 64GB RAM; i9-13900H CPU; Intel Iris Xe Graphics, NVIDIA RTX 3500 Ada Laptop GPU.
Vault Pro 2025.1 (30.1.63.0); Inventor Pro 2025.1.1 (241).
Frederick_Law
Yes, because all the referenced points, edges, faces are gone.
