Inventor Forum
Render Software
24 REPLIES 24
Message 1 of 25
2067 Views, 24 Replies
Render Software
Are there a Autodesk render software substitute for autodesk showcase? i want to render my model created from inventor 2018
24 REPLIES 24
Message 2 of 25
johnsonshiue
Hi! Have you tried using Inventor Studio or Inventor Presentation environment?
Many thanks!
Software Test Engineer
Message 3 of 25
Neil_Cross
That was the polite corporate answer Smiley Very Happy
The proper answer is no, there is no substitute for Showcase.  Inventor can replace showcase in that yes Inventor can create a render... in the same way that sitting in a shopping trolley and free rolling down a hill is a replacement for a car for your transport needs.
Inventor can't real time render on the GPU, Inventor doesn't... well, Inventor can't do almost anything that was unique to Showcase.  VRED is the closest match in the Autodesk portfolio but that isn't financially viable for most people/businesses.
Message 4 of 25
in reply to: Neil_Cross
Hi! Neil_Cross thanks for sharing that information that explain why the GPU load is under 5% when i'm rendering in inventor, i did try downloading the vred trial and currently playing but i feels like a bit of a hell hard to learn, UI is not like a user friendly like in the showcase.
Message 5 of 25
in reply to: johnsonshiue
Hi!
I use inventor presentation but its is lacking the ability to render the animation i created that is why i use showcase for animation but since i am using 2018 i cannot open in showcase.
For the inventor studio I did try and it has the ability to render animation but i have a little problem because there are thing i cannot do but maybe because i do not know how to use the full capability. I need to learn using the inventor studio since i do not have any option so who knows maybe a week or another week i could utilize it full capability.
Message 6 of 25
Neil_Cross
Inventor doesn't throw much through the GPU pipeline, it mostly computes what you see on the CPU and the GPU is used to throw that at the display... and because 3D CAD isn't visually very busy, the GPU never has much to do.  All the rendering modules in Inventor are ray traced which again is 100% CPU bound.
If you want to learn more about Inventor Studio, I did this which is 2 years old but still valid for today:
I've had a recent request in to do a video on how to animate movement in Inventor Studio so I'm working on that for a near future new video.  Get subbed if you want to stick around for when that comes out Smiley Happy
Message 7 of 25
Hi
Message 8 of 25
Neil_Cross
Thanks for the sub Smiley Happy
Yep that's me, I've got two courses on there now and a Vault Pro course about to go live in the next week or so.
Message 9 of 25
OK thank you for the conversationSmiley Wink
Message 10 of 25
kelly.young
@Anonymous it sounds like you have the knowledge of Inventor and assemblies but might need a bit of help with the studio environment. What kind of animation characteristics are you to trying to accomplish? Gears, assembly, explosion, rotation? In a general explanation making component constraints and dimension parameters "Key" and then importing them in the Studio environment under Parameter Favorites and then Animate Parameters, driving them will give you the same results as the presentation environment, just takes a bit of work. If you peruse @Neil_Cross stuff you will come across some good animation techniques, especially his "delicious" gears. If you have files to share someone might be able to give you a good start.
Please select the Accept as Solution button if a post solves your issue or answers your question.
Message 11 of 25
in reply to: kelly.young
Message 12 of 25
kelly.young
Yeah... Inventor isn't really the medium to which that would be best suited. I would recommend a tertiary product like 3ds Max. This is a bit beyond the scope of what Inventor is intended for. Hypothetically you could animate a light source to traverse the model if you started underneath a custom part set as the ground and as it came into view around the edge of the ground it would raise up and over. If you attempt it I would be interested to see how it turns out!
Message 13 of 25
Thanks Kelly ill try to spare a time learning inventor studio, because currently i'm trying the VRED Free trial
Message 14 of 25
After a 2 weeks of playing on the Inventor Studio the result was very dis appointing i've created set-up my work almost 75% completed to pressing the render button with just changing the background scene, moving component and many others the inventor studio crashed with in the two week i never completed a rendered model, At first i was happy because the deeper i learn the inventor studio i was amazed of how powerfull it is but the deeper i learn the inventor studio become unstable and full of crashed
Message 15 of 25
Neil_Cross
Probably a co-incidence, but I released this last night all about Inventor Studio...
Message 16 of 25
Hi Neil,
After watching your video, i can say that im not the only one having a problem about changing scene Ahhh! im frustrated
Message 17 of 25
admaiora
Showcase was a great software and at the moment there is not a similar alternative in Autodesk.
In Showcase you can:
- manage very big assemblies
- obtain good visual quality in a very short time, for static renders and for animation (i can realize and render with a global good material, light, shadow, etc,  15 min video in less of 30 mins work.
-in a very intuitive way, move, rotate, scale a model, position a key, move cameras, with a very few commands and a very quick learning curve
-  open a large ammount of files formats
- do very impressive things without being a genius in the multimedia field.
I can't do these things with the same high rate quality-simplicity/time  in AutoCAD, neither in Inventor Studio, neither in Fusion 360, neither in v Red, neither in 3ds Max or Maya.
Mechanical designers/engineers want this:
-great visual results without having to learn complicated programs
- create, even long, videos in an easy way even of big assemblies in a very short ammount of time
-use softwares that are perfectly in tune with the main 3d mechanical programs (es. Inventor)
Showcase did this.
Admaiora
_____________________________________________________________________________
Facebook | Twitter | Youtube
Message 18 of 25
in reply to: admaiora
Yeah that's all the thing i wanted but i could not do anything since Showcase cannot open inventor 2018 model so i'm stuck on how to get the job done without showcase, i'm frustratedSmiley Sad
Message 19 of 25
admaiora
Hi Marlon,
have you tried to export in step format then import it in Showcase?
Admaiora
Message 20 of 25
Hi
sometimes when have a no choice. the reason i don't want to export in step is i want the linked not to be broken.
