Inventor Forum
Rename Origin Planes
11 REPLIES 11
Message 1 of 12
919 Views, 11 Replies
I am creating some new template files. Is it correct that I am able to rename the origin planes in a part file but not in an assembly file? I would like to rename the origin planes to "TOP", "RIGHT" and "FRONT".
11 REPLIES 11
Message 2 of 12
zma1013
zma1013
I don't know if you can rename the origin planes or not. Never tried it.
But I'm not sure it's such a good idea to specifically name them Front, Right, and Top as this may create some confusion for people later on when you start assembling parts together. You may run into situations where you're constraining the Front plane of one part to the Top plane of another part and as I said it may cause some confusion. On second thought though, I guess I never really pay attention to the default origin names anyways, I always just highlight them and visually check to make sure that the orientation is the proper way I want it.
IV2012
Windows XP SP3 32-bit
Intel Core 2 Duo 6400 @ 2.13 GHz
Nvidia Quadro FX 3450/4000 SDI 256MB Vram
2 GB Ram
160GB HDD
IV2012
2 GB Ram
160GB HDD
Message 3 of 12
A little consistancy between part and assembly files would provide less confusion.
Message 4 of 12
zma1013
zma1013
I'm just saying your part's Front plane isn't going to necassarily match up with your assemblies Front plane. Try it out and see, I've not done it and I actually don't look at the names of the origins myself.
IV2012
2 GB Ram
160GB HDD
IV2012
2 GB Ram
160GB HDD
Message 5 of 12
swalton
swalton
You are correct, as far as I know. (IV2009). I would like to rename assembly origin planes as well. Most of my designs run on a railroad. I don't usually care how the part planes and the assembly planes line up, but it would be nice to re-name the xz plane as "Top-Of-Track" and the xy plane as "Rail-Centerline" in my templates so all of my users build their assemblies with these references.
Steve Walton
Inventor 2024
Vault Professional 2024
Steve Walton
Inventor 2024
Message 6 of 12
All of our equipment is located in space with
respect to three planes - the furnace centerline, the centerline of the
discharge table, and the passline.  We use skeletal modeling
techniques extensively.  Our part templates have the origin planes
renamed to conform to our aforementioned standard, but we can't do that with the
assemblies (and actually, that's where they're needed the most).  It would
be nice.
brian r.
iwaskewycz
style="FONT-SIZE: 14pt; FONT-FAMILY: Verdana">inventor
specialist
href="http://www.corefurnace.com/">core furnace systems
be nice.
brian r.
iwaskewycz
specialist
Message 7 of 12
As a workaround, I have an assy template with user planes named 'Mach CL', 'Mach Dir Origin' and 'Floor', constrained to the appropriate origin plane and grounded, that I use as substitute origin planes. One drawback is that they can get shuffled around in the browser during the course of a project.
Paul Cunningham
Paul Cunningham
Message 8 of 12
Andrew
In the company I work for we have internal rules about how to place our components according to the origin planes.
Renaming the origin planes in assemblies, as it is possible in the part files, will be a great help in our daily work.
So maybe Autodesk will make this possible in a future version of Inventor.????
Thomas
Andrew
Thomas
Message 9 of 12
I've done essentially the same thing, Paul.
It's just a bit aggravating to have to create three additional workplanes that
are identical to the origin planes solely for the purpose of naming
them.
brian r.
iwaskewycz
specialist
them.
brian r.
iwaskewycz
specialist
Message 10 of 12
But if you make that assembly a template, you only had to do it once,
right?
brian r. iwaskewycz wrote:
> I've done essentially the same thing, Paul. It's just a bit aggravating
> to have to create three additional workplanes that are identical to the
> origin planes solely for the purpose of naming them.
> *brian r. iwaskewycz*
> */inventor specialist/*
> *core furnace systems <>*
right?
Message 11 of 12
Yes, naturally.  It just looks out-of-place,
having three grounded workplanes at the top of the assembly browser when there's
already three perfectly good (though unnamable) ones inside the origin
folder.
It's already happened before that we got a new
Inventor designer in here, was working on some piece of equipment, and somewhere
along the way, deleted our workplanes.  His assembly was no longer located
in space correctly with respect to the passline, centerline of furnace, and
centerline of discharge table.  When asked why he found it necessary to
delete them, he said, "I didn't know what they were and just used the origin
planes instead."  Now I'm certainly not blaming Autodesk or anyone else for
that matter for what effectively was a failure to communicate a procedural
protocol and convention to him, but things would have clearer if the origin
planes themselves could bear the names of their real-world
counterparts.
That's all I'm going to post on this
subject.  It's such a minor gripe that it's not even worth griping
about.  Autodesk, just let us rename assembly workplanes - honestly, how
hard could it be?
brian r.
iwaskewycz
specialist
style="FONT-SIZE: 14pt; FONT-FAMILY: Verdana">core furnace
systems
folder.
counterparts.
hard could it be?
brian r.
iwaskewycz
specialist
systems
Message 12 of 12
Correction of last sentence -
Autodesk, just let us rename assembly origin
planes
- honestly, how hard could it be?
brian r.
iwaskewycz
specialist
planes
brian r.
iwaskewycz
specialist
