Inventor Forum
Inventor 2010 - Tooling
7 REPLIES 7
Message 1 of 8
351 Views, 7 Replies
I cannot past through tutorial exercise 3 - Core and cavity considerations with Moldflow. it is all ok up to stage - Defining the patching and runoff surface - where computer start patching calculation and then sort of seized using about 25% processor capacity and approx 98% of RAM memory from total 8 GB. The process creates a lot of (sometimes hundreds and other time thousands) Hard Faults / sec - according to 'Resource Overview" monitor. Similar situation i have noticed when doing Tutorial 2 - Family mold design. I have overcame the problem by finishing all processes up to patching calculation on one part – handset top before inserting the other part – handset bottom and doing it separately.
Does somebody have any advise – resolution.
Hardware: AMD 9500 – video Quadro FX 1800 – Vista Ultimate – 8 Gb RAM.
Cheers Edited by: 2grumpy on Jun 16, 2009 10:02 AM
7 REPLIES 7
Message 2 of 8
style="TEXT-JUSTIFY: inter-ideograph; TEXT-ALIGN: justify; MARGIN: 0in 0in 0pt"
class=MsoNormal>
style="FONT-FAMILY: 'Times New Roman','serif'; FONT-SIZE: 12pt; mso-fareast-font-family: 'Times New Roman'">We
tried the same workflow following the tutorial, but cannot reproduce the issue
as you mentioned. I am not very sure about the impact of the environment
configurations like Hardware or OS, we will go through the workflow on a
similar
style="FONT-FAMILY: 'Times New Roman','serif'; FONT-SIZE: 12pt">desktop
(Vista&8Gb RAM).
style="FONT-FAMILY: 'Times New Roman','serif'; FONT-SIZE: 12pt; mso-fareast-font-family: 'Times New Roman'">Before
we get the actual reason or any conclusion, could you please check if the
Moldflow analysis is in progress while you are performing the mold commands
(Patching&Runoff surface or Core&Cavity generation)?
style="FONT-FAMILY: 'Times New Roman','serif'; FONT-SIZE: 12pt"> If so, you can
wait for the process running to end and then continue to the next steps, and see
if it could be better.
class=MsoNormal>
style="FONT-FAMILY: 'Times New Roman','serif'; FONT-SIZE: 12pt; mso-fareast-font-family: 'Times New Roman'">Anyway,
we are investigating the issue and will keep an eye on it. Thanks for the
reporting.
class=MsoNormal>
face=Arial>
class=MsoNormal>
style="FONT-FAMILY: 'Times New Roman','serif'; FONT-SIZE: 12pt; mso-fareast-font-family: 'Times New Roman'">Best
regards,
class=MsoNormal>
style="FONT-FAMILY: 'Times New Roman','serif'; FONT-SIZE: 12pt; mso-fareast-font-family: 'Times New Roman'">Henry
class=MsoNormal>
similar
(Vista&8Gb RAM).
class=MsoNormal>
reporting.
class=MsoNormal>
face=Arial>
class=MsoNormal>
regards,
class=MsoNormal>
Message 3 of 8
Henry,
i did try to do that exercise 3 times today progressively uninstalling some software as Astroid drivers and Adobe AIR - no results. I do not have any suspicious software installed except MS Office 2007. Adobe Acrobat and Flash Player, printers etc. I have switched off Ad-Aware during testing.
Still, can do patching to single part – takes approx 5-6 sec.) However, cannot it if two parts in.
Valdemar
Henry,
Valdemar
Message 4 of 8
files attached
files attached
Message 5 of 8
and remaining
and remaining
Message 6 of 8
jessepeng
jessepeng
Archived Account
1. For issue in tutorial 2, the problem you met happens in 64-bit system. There are 2 workarounds:
1) If you want to run in 64-bit system, you can input shrinkage value "0.49" manually in the step set part shrinkage for "Exp-Mobile Top".
2) Use 32-bit system to do exercise, then it should be OK without any workflow change.
2. For issue in tutorial 3, the problem you met happens in 64-bit system too. There are 2 workarounds:
1) If you want to run in 64-bit system, you can set isotropic part shrinakge value to intead the suggest part shrinkage value. For example, set part shrinkage as "0.5" with isotropic setting is checked.
These 2 issues have been raised in team and we will keep track of them. Thanks for your post.
Message 7 of 8
In the future will you have similar facility for bevel gears?
It would be fantastic
Sorry, that comment was intended for different thread Edited by: 2grumpy on Jun 25, 2009 10:45 AM
Message 8 of 8
Another workaround (64-bit) with a non-isotropic material is to construct the patching surfaces manually.
This is a very frustration, but work and it is possible to use a shrinkage non-isotropic.
Un altro workaround (64 bit) con un materiale anisotropo è quello di costruire le superfici di chiusura manualmente.
E' una vera frustrazione, ma funziona ed è così possibile usare un ritiro anisotropo.
