removing quotes from angle dimensions and hole dimensions
andrew.nao
andrew.nao
in the attached image, i keep having quotes in my hole dims and my angle dims. if i edit my dim styles and remove the quote from the "suffix" box in the text tab, the quotes also are removed from my linear dims. where do i go to remove the quotes from my hole and angle dims but keep them in my linear dims? thanks
Curtis_Waguespack
HI @andrew.nao ,
Going from memory, the solution is to create 2 dims styles on that has the suffix and one that does not, then assign the one without to the dimension types that you do not want the suffix on,  using the Object Defaults to do the assigning.
I hope this helps.
Curtis
johnsonshiue
Hi Andrew,
I don't think you are using the best workflow here. In the drawing, go to Manage -> Styles and Standard Editor -> find the dimension style of interest -> change the unit to "ft" -> set Linear to Fraction and use appropriate precision. The quote will appear in the dimension but not in the hole note.
Many thanks!
Software Test Engineer
andrew.nao
hi, thanks. that worked but it there a way to keep it in just inches? and not use feet and inches? so if i get 2'-7" i need it to be 37" thank you for your help
johnsonshiue
Hi Andrew,
Unfortunately, I am not aware of other ways to enable "double quote" for inch without showing "single quote" for foot.
Many thanks!
