Blury lines in sketch mode
RobertKarlsen
RobertKarlsen
Hi!
I have changed some settings in my graphic`s.
I run K4000 card from nvidia.
What is the best settings for me? what do i need to adjust to get rid of the blury lines?
Im working (at most) with small assemblies. Maby 20-30 parts. So i want quality.
On a 3D model i see the lines are blury too, and the edges can have the same as the lines in windows paint 🙂
Like pixel for pixel. How can i make this better?
Thanks!
Robert.
Mark.Lancaster
@RobertKarlsen
Inventor version?  What updates have your applied?
Graphics driver date?
Windows OS?
What do you have for Tools/Application Options/Hardware?
If you select the diagnostic button, is it using your correct NVIDIA card?
Mark Lancaster
RobertKarlsen
Inventor version? 2020
What updates have your applied? what do you mean?
Graphics driver date? 353.62
Windows OS? W10 64bit
What do you have for Tools/Application Options/Hardware? Can you explain what you mean? 🙂
If you select the diagnostic button, is it using your correct NVIDIA card? where do i see that?
Thanks for your help!
Robert.
Mark.Lancaster
@RobertKarlsen
Well 2020 was just released so there's no update but we had no clue what version you had.
That's a driver build #, I asked for the date..  Smiley LOL    Go directly to Windows Device Manager and locate your graphics card under display adapter.  Right mouse click on the card and select proprieties.  Go to the "Driver" tab and look at the driver date.
Also with 2020 what do you have set here:
Tools/Application Options?
Mark Lancaster
johnsonshiue
Hi! The image seems to show the graphics is run on Conservative mode. Make sure you change it to Performance or Quality (Tools -> App Options -> Hardware). What resolution and DPI are you running?
Many thanks!
Software Test Engineer
