I am making a chest with parts i got from a teacher and i need to put them together into a chest. The sidewalls in the chest have nudges that goes into the front and back walls that cause z-fighting. We are not allowed to edit the objects themselves but so how can i "remove" material from the front and back panel to make them fit together?
Solved by blandb. Go to Solution.
Solved by mluterman. Go to Solution.
You can choose to Copy objects as well. If you edit the front or back panel in-context of the assembly, then choose the drop down of the Modify Panel > Copy Object, you can bring the side panel in as a surface. Then use that surface as a sculpt-cut. If you keep associativity on, it will continue to work until the design is done. Then you can turn the adaptivity off. Just another option.
