Inventor Forum
Rack and Pinion help
3 REPLIES 3
jakebuell
287 Views, 3 Replies
I have a rack driving a pinion dirving a rack.  When I create just these parts, the one rack drives the other rack just as intended.
Unfortunately, the intent is th have the rack and pinion assembly be part of a larger machine, but when I insert it into the larger assembly it no longer works.
Any thouhgts?
Thank you
Jake
3 REPLIES 3
WHolzwarth
in reply to: jakebuell
Smiley Wink Inventor's constraint handling needs improvement.
Walter
Walter Holzwarth
mdavis22569
You can't make the assembly flexible , and / or use positional views?
Mike Davis
JDMather
If setting the sub assembly as Flexible (required), then Dynamic Simulation Environment will be required.
Attach your assembly here if you can't figure it out.
