I have a rack driving a pinion dirving a rack. When I create just these parts, the one rack drives the other rack just as intended.
Unfortunately, the intent is th have the rack and pinion assembly be part of a larger machine, but when I insert it into the larger assembly it no longer works.
Any thouhgts?
Thank you
Jake
Inventor's constraint handling needs improvement.
Walter
Walter Holzwarth
You can't make the assembly flexible , and / or use positional views?
If setting the sub assembly as Flexible (required), then Dynamic Simulation Environment will be required.
Attach your assembly here if you can't figure it out.
