Message 1 of 10
"Replace Model Reference" always uses the worst view
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
How can you choose what view is front for "Replace Model Reference" in drawings?
If the model it's replacing is facing front, it will use the top. If it's facing back then it will use the front. If it's facing top then it will use a side.
Changing the 'front' in the model seems to do nothing. Changing the 'home' in the model seems to do nothing. I've played around with the "front view plane" in the drawing (tried both XY plane as "front" and "from model", with no difference.
When picking the new reference "design view" is set to "last active" and this seems to do nothing also, as it will always default to the same as above, even if "front" was last active.
