"Replace Model Reference" always uses the worst view
alexander_anderson4353E
Message 1 of 11
How can you choose what view is front for "Replace Model Reference" in drawings?
If the model it's replacing is facing front, it will use the top. If it's facing back then it will use the front. If it's facing top then it will use a side.
Changing the 'front' in the model seems to do nothing. Changing the 'home' in the model seems to do nothing. I've played around with the "front view plane" in the drawing (tried both XY plane as "front" and "from model", with no difference.
When picking the new reference "design view" is set to "last active" and this seems to do nothing also, as it will always default to the same as above, even if "front" was last active.
Replies (10)
Message 2 of 11
SBix26
Can you provide an example data set (drawing plus before and after models)?  What version of Inventor are you using?
Sam B
Inventor Pro 2027 RTM | Windows 11 Home 25H2
Message 3 of 11
Build: 233, Release: 2026.1.1
If i set one of the parts to have the 'top' as 'front', and replace references where the primary on the sheet is 'front' then that view will simply be replaced with the 'bottom'. Inventor will not reorientate it so that the 'front' view replaces the 'front' view in the drawing.
Message 4 of 11
SBix26
Hmm... I replaced Part2 with Part 4 and found that the Top view of Part2 was replaced with the Front view of Part4.  This makes sense to me, as I would expect Inventor to maintain the orientation of the origins of the parts relative to each other.
So, it appears that Replace Model Reference ignores direction labels and replaces views with the new model's XYZ axes oriented the same as the original's axes.  To me that makes sense.
Sam B
Message 5 of 11
lauri_barnhart
Hi @alexander_anderson4353E, thank you for your question.
Did the response provided by @SBix26 help answer your question?
If yes, feel free to click on the Accept Solution button.
This helps other users benefit from the information.
In case you still need help, please provide an update here so we can help you best moving forward.
Best,
Lauri | Community Manager
Message 6 of 11
No, the response didn't.
If the parts are complex enough, the issue remains, regardless of how the models are orientated. I can have two parts that both have the XY+ plane as "front" and model the same from there and if there enough difference in specifics then when replacing one with another, inventor will do as i said originally along with deleting all placed dimensions.
Simple parts will do as @SBix26 described, and i've realized that i cannot give the exact files that i am experiencing with as they are proprietary (and i would guess this limits a lot of discussions here.)
I am not able to share specifics about the .ipts on an open forum.
Message 7 of 11
johnsonshiue
The behavior does not sound right. It should persist per drawing standard preferences. If possible, please share an example that exhibits the behavior with me directly johnson.shiue@autodesk.com. I would like to understand the behavior better.
Many thanks!
Software Test Engineer
Message 8 of 11
lauri_barnhart
I wanted to check in and see if you saw johnsonshiue's follow up request and if assistance is still needed or if you found a solution to your question already? Please share any available information so the community can assist you further.
Message 9 of 11
johnsonshiue
Hi! Just to share some update on this issue, I did receive the files Alexander shared. Without disclosing the details, I can comment as such. The issue here is about choosing the starting plane. On one part, it was starting from XY plane, while on the other it was starting from XZ plane. The inconsistency causes the ViewCube to orient differently. It is better to have consistent starting plane and ViewCube orientation.
Many thanks!
Message 10 of 11
lauri_barnhart
Did the response provided by johnsonshiue help answer your question?
Thanks!
Message 11 of 11
Cris-Ideas
For the view in the drawing TOP, BOTTOM, FRONT ... etc. have no meaning.
View presented on drawings is bases on X,Y,Z of the model.
If your models do not follow the same X,Y,Z / FRONT,TOP, BOTTOM ... they will not replace facing the same way.
You need to keep your model X,Y,Z orientation consistent to replace models without view angle problems.
Some workaround my be to place your assembly in another assembly orientated consistently with your original model you are replacing. Than use this assembly as model for replacement.
Cris.
Cris,
https://simply.engineering
