Split Table Issues
Split Table Issues
harvey3ELEA
Message 1 of 15
Split Table Issues
harvey3ELEA
Any suggestions as to why my split parts list table keeps rearranging/splitting itself randomly between Inventor sessions?  Table arrangement worked well yesterday, but upon opening the drawing this morning, it has gone haywire.
It's roughly 60 entries that won't fit my 11x17 landscape drawing format, thus the need for the split.
It's proving to be a PITA to keep un-splitting/re-splitting it get it back to its proper form.
Replies (14)
Message 2 of 15
johnsonshiue
Hi! Could you check the file modified date and time? Is it the time you saved the file last time?
Are there other users editing the files at the same time? Where are the files stored? One Drive?
Many thanks!
Software Test Engineer
Message 3 of 15
harvey3ELEA
@johnsonshiue
Upon revisiting this split table randomly unformatting itself (unsplitting):
- no other users accessing this IDW or its models
- files stored on an in-house server with a dedicated partition (for all of our CAD work)
- modified date and time doesn't seem to be tied to the issue
Odd thing is, the 2nd column of the original split table remains in place atop of the sheet where placed (I'll post a picture when it happens again).
Message 4 of 15
johnsonshiue
Hi! I will need to see an example of such random split table behavior. It does not sound right to me.
Many thanks!
Message 5 of 15
harvey3ELEA
@johnsonshiue
Johnson,
Here's an example of a split table that just rearranged itself.  The part #'s are still in the correct sort order, but the table decide to randomly split itself after the 73-m001 part.
The correct table had the longer portion to the left at the drawing's inception.
Harvey
Message 6 of 15
harvey3ELEA
@johnsonshiue
And another one (different drawing)...
This one rejoined (unsplit) the long table to the left and off the drawing sheet (as it was originally placed), lost the split to the right, yet kept the right-hand column heading in place.  Strange.
Message 7 of 15
johnsonshiue
Hi Harvey,
Please share the Inventor files in zip with me johnson.shiue@autodesk.com directly. I would like to understand the behavior better.
Many thanks!
Message 8 of 15
harvey3ELEA
Don't think I'll be allowed to release the drawings and assemblies, but I'll check.
Funny thing is, I have opened both of those drawing numerous times over the last couple of months and the split table worked properly up until the other day when both were opened in the states you see above.
Can't figure out if part changes, additions, or subtractions are causing these anomalies.
Message 9 of 15
andrewiv
I have to ask if there is a reason that you are using split table?  When you split the table it basically keeps the two tables a separate entities that can be manipulated individually and maybe that's what you want.  The method I have always used is to edit the parts list, right click on what I want to be the last row and select "Wrap Table at Row".  This will accomplish something similar to splitting the table, but it will still behave as one entity and ensure that the two tables are connected.  You can wrap tables to the left or to the right by going into the table layout window.
Andrew In’t Veld
Designer / CAD Administrator
Message 10 of 15
harvey3ELEA
Thanks, Andrew. Never really paid much attention to that option as the split table has always been good enough, but I like your method better (as long as it keeps the formatting)!
Using your method, is there any way to create a small gap between the two lists to show some distinction between them?
Message 11 of 15
andrewiv
Not that I know of.  Part of the reason I like it is I like the tables to share a border and I don't have to drag the second table by hand to match them up.
Andrew In’t Veld
Message 12 of 15
harvey3ELEA
Thanks again.  Looks like your method is superior, and I agree about keeping the part list as one entity for editing and moving around the sheet.
Looks like the right way to go to avoid my periodic split table quirkiness too.
All that time where I've seen that, but never bothered to investigate it.  This old dog has learned a new trick!
Message 13 of 15
tkhudanianZLS6K
Community Visitor
Community Visitor
Where i can find "Wrap Table at Row"
Message 14 of 15
harvey3ELEA
Double click the Parts List on your drawing, then right click on the row that you want to the split to occur (Wrap Table at Row).
Using the "Table Layout" button at the top of the Parts List, you can tell the split to happen to the right or left, depending on your formatting preference.
Message 15 of 15
andrewiv
Andrew In’t Veld
