Hi !
Is it possible to show part name of several parts in 3D by comment or text leader ?
Directly in 3D mode, without create drawing.
For example to show someone the part numbers of certain parts very quickly and visually
Thank you very much!
It's very quick in the drawing environment.
Try this:
https://www.youtube.com/watch?v=71779CB3q9M
You can do it in the 3D annotation ribbon, but not nearly as quickly as you cannot copy and paste the leaders in the same way:
3D annotations can do this with leaders, but you'll have to select the property every time you apply it to a part.
Apologies for the weird angle view, can't show the actual assembly.
Niels van der Veer
Inventor professional user & 3DS Max enthusiast
Vault professional user/manager
The Netherlands
Using ‘Autodesk NavisWorks manager’, you should be able to view properties such as part numbers.
