Inventor Nesting 3d model export
Hi, Can anyone help me with a problem that im having for some time. Im trying to create a 3d model of a nesting sheet.
The various parts have a chamfer feature, when i try to create the model by using assembly file sometimes it doesn´t do anything, and sometime only create one part out of ten. I don´t know what im doing wrong.
I already tried the different options on the image.
Thank You
WillsonLeng
@Anonymous ,
Could you try to use another empty folder for "Folder for assembly Components"?
Willson
Hello. Thank you for answering. Yes already tried another folder and sub-folders, all empty.
WillsonLeng
Hi @Anonymous,
Sorry about that. Is that possible to share your data to us? So we can have a try to reproduce the problem. Also, could you let me know which Nesting version you are using?
Willson
Im sorry but i cannot share data. Also im using autodesk vault for getting the parts for the nesting, and when do create 3d model its also going to vault workspace, i dont know if this could complicate things.
This is the version that we are using.
Thank you.
WillsonLeng
Understood. So, is that possible to try to use Nesting 2022? We fixed a missing parts issue there.
Willson
Hi. We are still using the 2021 version, but i think we are about to change to 2022 very soon. Also, it was the Autodesk Vault that was causing the problem, as soon as i stop doing nesting using the vault workspace, it solved the problem.
I created a part using a folder in my desktop and then i nest that part to a sub-folder, and it worked fine.
Thank you very much for your support.
Helder
