QTY = 0
QTY = 0
johan.degreef
Advisor Advisor
QTY = 0
johan.degreef
Again this happens - don't know why
I know there are issues with QTY being 0 when using Model States (right?)
I did not use model states in whole my project but sill get this. Never had this before. Anyone suggestions?
I did suppress these parts.
Inventor 2025, Vault Professional 2025, Autocad Plant 3D 2025
johnsonshiue
Hi Johan,
Though you did not create a new Model State, the default Master Model State is also a Model State. You can suppress components as you wish. Their quantity will become zero.
Many thanks!
Software Test Engineer
bradeneuropeArthur
@johnsonshiue
That we now can edit the Master Design State is confusing people since it was never possible over the years!
@johan.degreef
I see this happen here also often enough. You need to go through old model files and take a quick look if everything is correct migrated.
Maybe it helps maybe not:
Dim p As PartsList = ThisDrawing.Document.ActiveSheet.PartsLists.item(1)
For Each r As PartsListRow In p.PartsListRows
	If r.Item("QTY").Value =0 Then
		r.Visible = False
	End If
	Next
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
