Hi all,
A colleague & I have been trying and failing all day to create a punch tool from scratch.
I did however manage to modify the geometry of the Dimple & Hole example here:
http://www.cbliss.com/inventor/iFeatures/index.htm
Can anyone point me in the direction of step-by-step instructions for how to a) build the iFeature correctly and b) how to then extract it so that the orientation is not FUBAR when you insert it using the punch tool.
Attached are the dimensions I need.
This shape when revolved about the centreline should produce a 'dimple' effect in the sheet metal part.
Alex.
Alex Fielder
Inventor Expert
https://github.com/alexfielder/
LinkedIn - Github Inventor Extension Server - Bonkers polygon iLogic thing
Top ten iLogic Tips - API Shortcut In Google Chrome - Assembly Extrusion Example
Alex Fielder
Inventor Expert
