Equation curve t in user defined parameters
rb
rb
Working on some gnarly equation curves and I am trying to define phi as an user parameter.
Here is my phi: t*1rad-asin((a/r)*sin(t)
It seems like I can't enter t, as t from the equation curve feature, in a user defined parameter? t can only be referenced in the equation curve x(t) and y(t) input fields?
My already long and complicated equation, becomes even longer and more complicated when I have to input t*1rad-asin((a/r)*sin(t) at several instances rather than just phi.
The readability of the full coordinate is super poor because of this....
Or am I doing it wrong?
johnsonshiue
Hi! Indeed, the 't' is only understood within the implicit expression of an Equation Driven Curve (EDC). It isn't accessible outside of an EDC. Also, a user parameter has to have a definite value and it cannot be a variable.
Many thanks!
Software Test Engineer
rb
hi @johnsonshiue
i have reached some problems that i can't solve within the equation curve. i need more parameters to play with...
can i generate a custom sketch line figure from vba or rather ilogic
any documentation or guidelines showing how to generate custom shapes by code
thanks
rb
just for clarity, i have a working script in R code that works well to generate my shape, now i am looking for a way of running it directly in inventor and have it plotted straight into a 2d sketch or whoever it is done
johnsonshiue
Hi! If I understand your request correctly, you have the equations and also the points generated by the equations. You may simply enter the equations in Equation Driven Curve command. Or you may put the point coordinates in a text file or an Excel spreadsheet (X, Y, and Z). Then use Import Points command in 2D/3D Sketch environment to import the points. A spline will be created fitting the points automatically.
Many thanks!
rb
i think the import of xyz coordinates may work and be a good alternative
but is it possible to achieve the curve plotting from inside of inventor with ilogic  or similar, meaning that i don't need to generate my coordinates outside of inventor
preferably, i would like to have my code inside of inventor and avoid an external script to generate the coordinates and import them manually by excel
johnsonshiue
Hi! Yes, it should be doable. You may enter the equation in an iLogic rule to generate the points and fit a spline through the points. Or you may use Equation Driven Curve.
Many thanks!
