Punch Tool creation help
AlexFielder
Advisor Advisor
AlexFielder
Hi all,
A colleague & I have been trying and failing all day to create a punch tool from scratch.
I did however manage to modify the geometry of the Dimple & Hole example here:
http://www.cbliss.com/inventor/iFeatures/index.htm
Can anyone point me in the direction of step-by-step instructions for how to a) build the iFeature correctly and b) how to then extract it so that the orientation is not FUBAR when you insert it using the punch tool.
Attached are the dimensions I need.
This shape when revolved about the centreline should produce a 'dimple' effect in the sheet metal part.
Alex.
mcgyvr
http://www.widom-assoc.com/html/ifeatures_-_punches.html
http://usa.autodesk.com/adsk/servlet/item?siteID=123112&id=11767919
http://usa.autodesk.com/adsk/servlet/item?siteID=123112&id=11768082
http://au.autodesk.com/?nd=tech_talk_detail&article_id=10&jid=9835
AlexFielder
Thanks for the links mcgyvr; the first one is exactly what we needed. Smiley Happy
Speaking of which, do you have any idea why if I use as my centre point the point circled in the attached image; that the resultant iFeature doesn't align as you would expect?
JDMather
Can you attach the punch file and the part you pictured here?
Make sure when creating the Punch tool that you delect any autoprojected origin centerpoints from the sketches.
shallN6L5D
Hi there!
After 14 years, none of those links work any more>
Could anyone please point me to a more recent set of instructions for creating a sheet metal punch tool in Inventor?
You might think there would be such a thing within the Autodesk help docs for Inventor, but if there is, I can't find it!
cheers
Simon
johnsonshiue
Hi Simon,
Here are a few YouTube videos showing the workflow.
https://www.youtube.com/watch?v=18wtyUN1j7M
https://www.youtube.com/watch?v=TTB6Sed-9RU
https://www.youtube.com/watch?v=OYsXl4TAyxE
https://www.youtube.com/watch?v=m1AL-zIFkGY
If you still have more questions in terms of creating a reusable punchtool, please start a new thread. The forum experts can help take a look.
Many thanks!
Software Test Engineer
shallN6L5D
Thanks @johnsonshiue I do have more questions... I also have a support ticket open so I'll ask the questions there.
cheers
Simon
