Inventor Forum
Project Geometry
6 REPLIES 6
lkirit2000
1219 Views, 6 Replies
Project Geometry
I would like to create a line along the lines indicated by red.
I tried by projecting edges, but it is not success ?
Please see the attached image and CAD file !
Rgds
6 REPLIES 6
Xun.Zhang
in reply to: lkirit2000
Hello @lkirit2000,
It seems works fine in my end, can you please share more information such as a video might be great help to find the gaps between workflows from my side and yours.
Thanks!
Xun
lkirit2000
in reply to: Xun.Zhang
Hi Xun,
Thanks for your response.
Please can show in a video clip, It would be more helpful !
Rgds
johnsonshiue
Hi! Project command in 2D Sketch is like a combo command. Is it "Project Geometry" enabled?
Many thanks!
Software Test Engineer
lkirit2000
in reply to: johnsonshiue
Hi Johnson,
That's Great !
I just activated and now I can create the line from projecting edges.
Now another issue arises, COULDN'T TRIM ?
How I can Trim ?
Rgds
johnsonshiue
Hi! Unfortunately, the projected sketch cannot be trimmed. You can delete the project constraint but it will no longer be associative to the edges. Or, you can create another line on top of it so you can trim it.
Many thanks!
What is this? I am not so familiar with CAD. My workplace does use it but I really am not so concerned with that work. I am trying to learn and I try reading up as much as I can to learn
Technology Administrators
