Problem with Tutorials
menjodepeer
Observer Observer
Message 1 of 10
menjodepeer
Observer
Observer
Hello!
I hope you guys can help me.
Im new to Inventor as I used to work with Solidworks.
Im trying to start by doing some Tutorails inside the client but it doesnt seem to start:
Even after trying a couple of different times it seems to have no effect.
Thanks for the help!
Menjo
Replies (9)
Message 2 of 10
chris
what specifically are you trying to do?
Message 3 of 10
menjodepeer
Observer
Observer
Hello! Open the tutorial screen.
Message 4 of 10
chris
My tutorial screen opens fine, but what I am asking is what specifically in the tutorials are you trying to learn?
Message 5 of 10
JDMather
@menjodepeer
Post screenshot (Shift Win S and Ctrl v in a Reply) of what you see at this link...
Inventor 2024 Help | Get Started Tutorials | Autodesk
Should look something like this...
Message 6 of 10
menjodepeer
Observer
Observer
Hello!
Im trying to get used to different UI and controls.
The interactive Tutorials are a nice place to start i thought
Message 7 of 10
menjodepeer
Observer
Observer
That is the following:
I think it might be a problem with the proxy server in our Domain.
Do you guys maybe know which URL is used to get the data for the tutorials so I can whitelist it?
Thanks!
Menno
Message 8 of 10
A.Acheson
Hi @menjodepeer
What happen when you followed the on screen prompts to close the tutorial tab and reopen?
Can you check if there is files at this path?
Path is only a guideline and might not be correct in your situation. You can navigate to public documents manually then >Autodesk>Inventor2024>Tutorial Files
Users\Public\Public Documents\Autodesk\Inventor [version]\ Tutorial Files\
Regards
Alan
Message 9 of 10
chris
@menjodepeer  Regardless of the tutorials link not working, I think if you list off a few of the things you'd like to learn or have questions about it will be easier to get help or pointed in the right direction from the community or individuals.
Message 10 of 10
johnsonshiue
Hi! Please take a look at the following article.
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Tutorial-Gallery-d...
Many thanks!
Software Test Engineer
