Frequently crashing
Frequently crashing
faizibnurashid
Frequently crashing
faizibnurashid
Community Visitor
Community Visitor
The software crashing frequently while performing constrain of complex structures.
JDMather
@faizibnurashid
Can you Attach an example here?
Are all of your sketches fully defined?
Does Manage>Rebuild All return any errors?
Are any unresolved errors indicated in your Relationships folder?
johnsonshiue
Hi! Inventor should never crash. Please try the following and see if it helps.
1) Install all critical Windows updates and the latest graphics driver.
2) Install the latest Inventor update.
3) Clean up %temp%.
4) Make sure C:\Temp folder is available and open the assembly -> press Ctrl+F7 and scroll to the bottom of the dialog. Is there any bad body reported? If yes, please open the file containing the bad body and run through Repair Bodies workflow.
Please send me an email johnson.shiue@autodesk.com. I would like to dig up the crash report to understand the crash better.
Many thanks!
Software Test Engineer
