Inventor Forum
Problem with inventor vault add-on options
2 REPLIES 2
rene.bouiusC97WT
213 Views, 2 Replies
I can't change settings in my inventor vault add-on.
Every time i make a change, it just dispears when i close this window.
I want to turn off dialog suppression on check in dialog.
2 REPLIES 2
I've had the same issue.
The buttons are there but you can't see them. Not sure if it's a graphics / display issue or a bug.
You can select what you need and then TAB through to get to where the OK button would be. It was a bit trial and error counting through to eventually hit the right button.
Dave Cutting
It works like you said! You click a couple of times on TAB en Enter.
