I can't change settings in my inventor vault add-on.
Every time i make a change, it just dispears when i close this window.
I want to turn off dialog suppression on check in dialog.
Solved by dave.cutting. Go to Solution.
I've had the same issue.
The buttons are there but you can't see them. Not sure if it's a graphics / display issue or a bug.
You can select what you need and then TAB through to get to where the OK button would be. It was a bit trial and error counting through to eventually hit the right button.
It works like you said! You click a couple of times on TAB en Enter.
