Presentation + Find Tweaks Part is Used in
MechMachineMan
Advisor Advisor
MechMachineMan
With this new presentation system, in a snapshot, is there any way to find out what tweaks a part is used in?
In the old ipn system you used to be able to change the browser pane to one that would point this out, but now it seems there is nothing.
Looking for some way to do this for when I add parts in after the fact.
* I already understand it is easy enough if the tweak is visible, but if it is invisible, then how?
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
mdavis22569
I don't have my 2017 (laptop) with me  but :
Take a look at
https://knowledge.autodesk.com/support/inventor-products/learn-explore/caas/CloudHelp/cloudhelp/2017...
and check out
https://events.au.autodesk.com/connect/sessionDetail.ww?SESSION_ID=20713
watch the class and see his hand outs ...it really helped me with 2017 IPN's
Mike
Mike Davis
MechMachineMan
Thanks for the links!
Checked out the first one. Does seem to have what I want in it - find tweak based off of part to add more parts to the tweak.
Haven't made it to the second one.
I'm finding the fact that you can't change View reps (ie from my broken-link snapshot to a storyboard associative snap) is seeming quite limiting.
Also annoying how you can't even automatically find the part in the storyboard from the browser/graphics window...
Justin K
mdavis22569
I wasn't all that keen on the new way till I did this class ....
Really enjoyed it.. got a lot better understanding of how it works
Look at his downloads
@mcgyvr  This was one of the classes I was telling you about ...
Mike
Mike Davis
