Inventor Forum
Place and constrain several parts repeatedly
12 REPLIES 12
Message 1 of 13
Arnaldo_Gomes
433 Views, 12 Replies
I need to place several identical parts in an assembly and constrain them to the holes of another part.
I use the "Insert" constrain but this is a tedious process as I have to repeat the entire process for each ring.
Is there any way to speed up this process?
The circle in the ring is always the same so I would just need to match it to the circle hole.
Ideally I would place the ring in the assembly, choose the circle to match it and repeat.
Any help is appreciated.
12 REPLIES 12
Message 2 of 13
ampster40
in reply to: Arnaldo_Gomes
for quick work during that stage use iMates.
But the trade off is you need to set them up first.
HTH some
Message 3 of 13
Learn about iMate.
Kacper Suchomski
YouTube - Inventor tutorials | WWW | LinkedIn | Instagram
Message 4 of 13
Arnaldo_Gomes
in reply to: ampster40
From my knowledge, iMate is not a solution.
I have a lot of different parts like the green one (dozens) to match the rings to it.
So, I may be wrong but that would be time consuming too.
Message 5 of 13
Cadmanto
@Arnaldo_Gomes
My suggestion would be to create a mini sub assembly of the hardware then create an iLogic routine to place them.
@Cadmanto - this post has been edited due to Community Rules & Etiquette violation.
Windows 10 x64 -16GB Ram
Intel i7-6700 @ 3.41ghz
nVidia GTS 250 - 1 GB
Inventor Pro 2021
Best Regards,
Scott McFadden
(Colossians 3:23-25)
Message 6 of 13
blandb
Did you model the green part, or is this an imported "dumb base solid"? If you modeled the holes, you could utilize the "Sketch Driven Pattern" in the part, place the washer, bolt, etc then use the feature pattern command to fill all the holes. You have have to constrain 1 set for the top, 1 for the sides and 1 set for the front. Advantage is you can add/remove additional points and the assy will update. Please see the quick video attached.
Autodesk Certified Professional
Message 7 of 13
CCarreiras
I use also Sketch driven patterns to do this kind of work.
Usually, the holes are created at the end of the process, so, I just have to create the holes (and driven patterns) with the next step in mind: using the best strategy to placing washers later.
CCarreiras
Message 8 of 13
Arnaldo_Gomes
in reply to: blandb
Thanks for the reply.
The green part is a sheet metal part.
It is a good solution but still there is some prior preparation, and some parts are really complex shaped.
I think the best and fastest solution would be the "click-place" solution.
Message 9 of 13
Arnaldo_Gomes
in reply to: Cadmanto
Thanks.
I have no experience with iLogic, but i'll check it out with someone here who has.
I was hopping to have some easy solution to implement.
Message 10 of 13
iMate, turn off auto iMate.
Most CC parts has iMate already.
Part with insert iMate will mate to any holes, don't need iMate there.
You can Alt drag the part and mate them.  It'll take a few try to get used to it.
Message 11 of 13
Thanks!!!
That really speeds up the process.
Almost perfect.
I'll stick to it for now. 🙂
Message 12 of 13
blandb
I'm surprised ADSK never purchased KWIKSERT or developed their own version of it....
Message 13 of 13
karthur1
in reply to: blandb
Ditto.
