Hi ,
Please see the attached image, pipes are pressed at the corners. Is there any command that can apply directly or how I can do that ?
Rgds
Solved by Paul-Mason. Go to Solution.
Solved by IgorMir. Go to Solution.
Hi ikirit2000
You have forgotten to introduce yourself to the forum too. But I leave it up to you.
Here is a quick model for the end piece of the squashed tube. IV2018 format. Might not be 100% accurate but should convey the design intent to the fabricator.
Cheers,
Igor.
@lkirit2000 wrote:
Hi
I forgot to attach the image. Please see the attached image.
My humble effort attached, in IV 2019 format backwardly compatible with IV 2018 + update 3 or so they claim, Attached .. I hope
Hi Kiri,
That's better! Now I can address you by your real name raser then using some sort of nicknames, derived from your user name.
Cheers,
Igor.
@lkirit2000 wrote:
Hi Igor,
I am Kiri, Working as a Product Development Engineer.
Rgds
