Inventor Forum
Pipe Pressing
5 REPLIES 5
lkirit2000
686 Views, 5 Replies
Pipe Pressing
Hi ,
Please see the attached image, pipes are pressed at the corners. Is there any command that can apply directly or how I can do that ?
Rgds
5 REPLIES 5
lkirit2000
in reply to: lkirit2000
Hi
I forgot to attach the image. Please see the attached image.
IgorMir
Hi ikirit2000
You have forgotten to introduce yourself to the forum too. But I leave it up to you.
Here is a quick model for the end piece of the squashed tube. IV2018 format. Might not be 100% accurate but should convey the design intent to the fabricator.
Cheers,
Igor.
@lkirit2000 wrote:
Hi
Web: www.meqc.com.au
lkirit2000
in reply to: IgorMir
Hi Igor,
I am Kiri, Working as a Product Development Engineer.
Rgds
Paul-Mason
My humble effort attached, in IV 2019 format backwardly compatible with IV 2018 + update 3 or so they claim,  Attached .. I hope
Inventor 2025 Pro
HP Z420 workstation
Xeon 3.7Ghz CPU 8 Cores, 64 GB Ram
64bit (The Garbage known as) Windows 10 Pro
AMD FirePro V3900 (ATI FireGL) (1GB RAM)
Ashington Northumberland (UK) ~ Home to the WORLD FAMOUS Pitman Painters Group
IgorMir
Hi Kiri,
That's better! Smiley Happy Now I can address you by your real name raser then using some sort of nicknames, derived from your user name.
Cheers,
Igor.
@lkirit2000 wrote:
Hi Igor,
Rgds
