Part doesn't insert into drawing
Vagulus
Message 1 of 8
Vagulus
I have a part from which I wish to create a drawing.  I pull up a drawing from the template; go to 'Place Views --> Base'; move the cursor onto the drawing area - and nothing happens!
What would be stopping the part appearing in the drawing?
"If you can't explain it to a six-year-old,
you don't understand it yourself"
Albert Einstein
Accepted solutions (4)
Replies (7)
Message 2 of 8
-niels-
No issues here:
I'm using IV2018.1
From what i could tell you don't have the .1 update yet, maybe that could help.
Niels van der Veer
Inventor professional user & 3DS Max enthusiast
Vault professional user/manager
The Netherlands
Message 3 of 8
Fouad-l
All works fine here.
Could you please tell us a little bit more about your inventor version and workstation.
FOUAD LATRACH - MECHANICAL ENGINEER - ELCHE - SPAIN.
Please use the ACCEPT AS SOLUTION or KUDOS button if my Idea helped you to solve the problem.
ASUS ROG G703 : Windows 10 Pro - Intel i7 3.4 Ghz - 64 Gb RAM - 1.5 TB SSD - Nvidia GTX 1080 8GB.
Message 4 of 8
Vagulus
I can't follow why version would matter because I have done dozens of drawings since upgrading to 2018 and not had this problem.
My machine is Intel QuadCore i5-3470 CPU @ 3.20GHz, 32 GB RAM, running MS Windows 10 Home on an MSI B75MA-P45 motherboard.
It was assembled by Net Solution Computers of Morley, Western Australia, and has a SAMSUNG U28D590D VDU driven by an NVIDIA QUADRO K620 Video Card and RealTek High Definition Audio.
I have Windows Defender as Anti-virus with Firefox and Skype running in the background.
Albert Einstein
Message 5 of 8
salariua
Can you see your file in the base view window dialog? If the file is not open (in memory) then Inventor won’t select the file automatically for you.
I am pretty sure that’s not the case here but can you confirm this for us please?
Adrian S.
blog.ads-sol.com
AIP2012-2020 i7 6700k AMD R9 370
Did you find this reply helpful ?
If so please use the Accepted Solutions or Like button - Thank you!
Message 6 of 8
Vagulus
I can see it here
and here
but I don't know anything about a 'base view window dialog'.  How do I find that?
Albert Einstein
Message 7 of 8
salariua
How do you place a model in a drawing?
open the drawing, click the base view icon and browser for your part if the part is not open (in memory) already.
if you can't see a base view window dialog that might be because it opens off-screen, like if you changed from dual monitor to single monitor or from docking station to laptop only.
Adrian S.
blog.ads-sol.com
Message 8 of 8
Vagulus
Would you believe it?  I just pulled up a drawing, I clicked on Place Views --> Base' like always and
If Inventor was a Microsoft product I would just accept this as being temperamental.  I thought Autodesk was different ;}
Thanks folks.  It seems to have cleared up.
Albert Einstein
