Parent Sheet Zone parameter points to wrong zone
logan_masa
Message 1 of 9
logan_masa
Hi everyone,
I have noticed that the PARENT SHEET ZONE parameter seems to point to somewhere other than the actual view location. Moving the parent view to different locations does not update the parameter from B5, but moving the drawing view itself does. It almost seems as if the parameter is updating based on an arbitrary spot on the drawing location rather than the parent view location. Strangely, it works in the opposite direction - the VIEW SHEET ZONE parameter updates correctly. I also tested this out on the default en-US drawing template with the same results.
For reference, the parent view text is formatted as
<VIEW IDENTIFIER><VIEW SHEET INDEX>
and the detail view text is formatted as
DETAIL  <VIEW IDENTIFIER>
SCALE <SCALE> ~ <PARENT SHEET INDEX>.<PARENT SHEET ZONE>
Any help would be greatly appreciated!
Replies (8)
Message 2 of 9
johnsonshiue
Hi! Please make sure 2026.2.1 update is installed. If it does not help, please share the files in zip directly with me at [email protected]. I would like to understand the behavior better.
Many thanks!
Let us know how we did on Trustpilot.
Software Test Engineer
Message 3 of 9
logan_masa
Hi Johnson!
I have updated to 2026.2.1 and the behavior persists. Attached is a zip file of a part and drawing, as well as an exported .pdf to show what I see on my end. I used the Default project with the default template, and the detail view's parent sheet zone points to C5, while it should point to B7. It almost seems like the parameter is referencing the part/assembly center rather than the parent view location.
Please let me know if you can reproduce this on your end, or if there are any problems with the zip file.
Message 4 of 9
johnsonshiue
Hi Logan,
Many thanks for sharing the files! I took a quick look at the drawing. I think I know where the confusion is. The zoning label is based on the center of the view port. But when the view goes across multiple zones, the label can be confusing. Regardless, the point of the label is to ensure at lease part of the view be at the zone and it can be located easily.
Thanks again!
Message 5 of 9
logan_masa
Thanks for letting me know, Johnson!
Is there a way to make the zone system work with larger views? Many of our views are one large complex assembly that takes up most of the page. Our shop can already locate the assembly on the page with the Parent Sheet Index parameter, but they need to be able to find the location of the specific parent detail view at the correct zone.
Message 6 of 9
johnsonshiue
Hi Logan,
Unfortunately, I am not aware of a setting to change the behavior.
Many thanks!
Message 7 of 9
logan_masa
Thanks for letting me know Johnson!
Unless there is a way to do it with iLogic, it would be a nice setting to have. I'll submit it as a feature request later.
Message 8 of 9
pkomatlapalli
Hello, @logan_masa ,
Did the information provided by @johnsonshiue help you and answer your question?
If yes, please click on the "Accept Solution" button on the post(s) that solved your problem. This will assist other community users in finding and benefiting from this information.
If not, please do not hesitate to give an update in this thread so all community members receive an update on the progression of your question, and can suggest next steps that may be helpful for you to achieve what you're looking for.
All the best,
Pavan Kumar | Community Manager
Your question got successfully answered? Then just click on the 'Mark as solution' button.
Pavan Kumar
Message 9 of 9
pkomatlapalli
Hello @logan_masa ,
Just checking in—did the responses shared by @johnsonshiue  help clarify your question?
If so, please consider clicking the "Accept Solution" button on the post(s) that solved your problem. Doing so helps others in the community easily find useful answers.
If your question still needs more attention, feel free to reply here with an update. This way, other members can jump in with further suggestions or guidance to help you move forward.
All the best,
Pavan Kumar
