HI
I GOT SOME PROBLEMS IN PACK AND GO. I PACK AND GO FOR ONE DRAWING AND UPATE IT. BUT THE ORIGIANL FILE IS STILL EFFECTED AND UPDATE AUTOMATICALLY.
AND THEN SOME DRAWING GOT PROBLEMS IN VISUAL STYLE. IT LOOK TRANSPARENT. WHEN I CHANGE VIEW-PERSPECTIVE , THE DRAWING IS OK, BUT WHEN I CHANGE BACK TO VIEW-OTHOGRAPIC , ITS STILL LOOK TRANSPARENT.
PLEASE ADVICE HOW TO SOLVE THESE PROBLEMS,\
THNKS
THU YA
HI
THNKS
THU YA
I think i did not understand the whole picture of yours problems.
Admaiora
Admaiora
hI,
I'VE ALREADY GOT THE ONE DRAWING FOR PROJECT "A". I WANT TO USE THIS DRAWING FOR PROJECT "B" . SO I USE PACK AND GO COMMAND FOR PROJECT "A" DRAWING AND USE IN PROJECT "B". BUT WHEN I MAKE THE SOME CHANGES IN PROJECT "B" DRAWING , THE ORIGINAL PROJECT "A" DRAWING ALSO EFFECTED. IT UPDATED AUTOMATICALLY. I DON'T WANT TO EFFECT IN PROJECT "A" DRAWING. HOW SHOULD I SOLVE IT?
OTHER PROBLEMS IS IN VISUAL STYLE . THE DRAWING LOOK TRANSPARENT ALTHOUGH I CHANGE THE SHADED VIEW IN VISUAL STYLE. BUT WHEN I CHANGE THE PERSPECTIVE VIEW, IT'S OK. WHEN I CHANGE BACK TO ORTHOGRAPHIC VEIEW, STILL HAVE THIS PROBLEMS, PLEASE SEE THE ATTACHEMET,
THANKS
KYAW THU YA
hI,
THANKS
KYAW THU YA
You don't want pack and go ...
you want to copy design ..
The way you're doing it ..you'll need to replace model reference ...
Are you using Vault or an IPJ/project ?
WHY ...
you need to copy Design ...not pack and go
also are you using a project file for your job?
WHY ...
Ok ...so lets back up then...
What version of Inventor?
Have you done the tutorials?
Also are you using an IPJ?
So no you don't want to use a pack and go .... you want to use copy design ..however since you're not using vault, you'll want to do it in Design Assistant.
here is a google search of some good copy design via Design Assistant
you need it ... go thru the file management ...
also the link for the design assistant for copying ...
this will help you a lot ...
make sure you're up to date on ALL of your updates and patches too
https://knowledge.autodesk.com/support/inventor-products/downloads
There are a lot of people here who'll help ... now we have a starting point.
