I am trying to create a 100 mm ⌀ by 10 thk repad for a 4" SCH40 pipe return. Using a sheet metal part file attached, I am able to create a quarter section of the geometry required. When attempting to mirror and pattern the part to make the whole it comes a bit unglued.
Can somebody with more sheet metal experience please assist me?
Using Autodesk Inventor Professional 2016 64-Bit Edition Build 210 SP1
Robin
Solved by jordirg. Go to Solution.
I think a Split and Thicken would be the easy way.
