Hello, I am using the current version of Inventor 2022. If I want to align reused profiles in the frame generator, a random crooked value always appears in the Rotation field, e.g. 3.14159265358979. Annoying, because I always have to enter 0°. Is there a fix for this bug?
Hi! The behavior does not look right to me. The value seems to be pi. I am not sure why pi is used in this context unless the angle unit is set to radian, not degree. Let me work with the project team to understand it better.
Many thanks!
in general, it does not happen, Reuse Frame shows correct angle. Could you send me (jan.priban@autodesk.com) or enclose here dataset, that you can reproduce bad reuse frame angle on?
Regards
Jan Priban
