OBJ file to a solid
OBJ file to a solid
Message 1 of 10
OBJ file to a solid
How do I make this obj.file a solid part in inventor after its imported?
Replies (9)
Message 2 of 10
jhackney1972
You can download and install the Mesh Enabler from the Autodesk App Store if you are on subscription.  With this install and enabled in the Add-Ins manager, it will convert your imported OBJ file to a solid.
John Hackney, Retired
Message 3 of 10
Thanks, Is there a way to fix the mesh so I can split it in to and create various extrusions based on the model?
Message 4 of 10
jhackney1972
The mesh is very irregular and I am not having much luck with it as a solid.  I will have to pass on giving you any help in this area.
Message 5 of 10
WHolzwarth
Ok, Mesh Enabler does it's job with this rather simple case.
But the general problem is: Even if a mesh can be converted to a solid, it's outer surfaces still consist of thousands of tiny planar faces. Large file size and bad response times come along.
In this case I created a substitute revolved part, after some trials. There's been an intersection in the profile; I only found it after some partly revolutions. In the end I deleted intermediate bodies, but the file size still was big, because of hidden geometry in the file.
A STEPOut-STEPIn brought back acceptable file size.
2019 files attached. Additional clean-up is possible, resulting in less overall faces.
Walter Holzwarth
Message 6 of 10
patrik.hlebec.stor
Is there a way to retain face color data? I imported a posed person and he is now all gray.
Is there another way to import from Blender with vertex color data?
Message 7 of 10
JDMather
@patrik.hlebec.stor
Yes.
You must have the appearance data file in the same folder as the mesh file when opening.
Message 8 of 10
patrik.hlebec.stor
@JDMather I have attached the files below. You can also see the results of the import as advised above.
I have tried modern and legacy .obj file-type:
Modern obj:
 And legacy:
Re-import to Blender displays colors correctly.:
Message 9 of 10
JDMather
@patrik.hlebec.stor
Hmmm,
I have a jpg file too?
Message 10 of 10
Subtel
Thank you ... that worked for me to 😉
