Inventor Forum
Orientation of reused Profiles
3 REPLIES 3
g_froese
327 Views, 3 Replies
g_froese
Hello, I am using the current version of Inventor 2022. If I want to align reused profiles in the frame generator, a random crooked value always appears in the Rotation field, e.g. 3.14159265358979. Annoying, because I always have to enter 0°. Is there a fix for this bug?
3 REPLIES 3
talha.tufan523TD
in reply to: g_froese
talha.tufan523TD
Can you select the checkbox and try it?
johnsonshiue
johnsonshiue
Hi! The behavior does not look right to me. The value seems to be pi. I am not sure why pi is used in this context unless the angle unit is set to radian, not degree. Let me work with the project team to understand it better.
Many thanks!
Software Test Engineer
Many thanks!
jan_priban
in reply to: johnsonshiue
jan_priban
in general, it does not happen, Reuse Frame shows correct angle. Could you send me (jan.priban@autodesk.com)  or enclose here dataset, that you can reproduce bad reuse frame angle on?
Regards
Jan Priban
Regards
Jan Priban
